Ir para o conteúdo principal
Garmin Nuvi 265WT Screen Replacement
O que você precisa
  1. Garmin Nuvi 265WT Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Garmin Nuvi 265WT Screen Replacement: passo 2, imagem 1 %32
    • Lift up the screen gently and place it on the opposite side.
  3. Garmin Nuvi 265WT Screen Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Garmin Nuvi 265WT Screen Replacement: passo 4, imagem 1 %32
    • Lift up the screen and you're done.
Conclusão
Patricia Gonzalez
Membro desde: 10/10/16
337 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 6-4, Bennett Fall 2016 Membro de Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 456
