Ir para o conteúdo principal
Garmin Nuvi 260W Screen Replacement
O que você precisa
  1. Garmin Nuvi 260W Screen Replacement, Screen: passo 1, imagem 1 %32
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Screen Replacement: passo 2, imagem 1 %32
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Screen Replacement: passo 3, imagem 1 %32 Garmin Nuvi 260W Screen Replacement: passo 3, imagem 2 %32
    • Once the screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Screen Replacement: passo 4, imagem 1 %32
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Screen Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to loosen the three clips located on the top of the screen encasing to a position that loosens the hold on the screen.
  6. Garmin Nuvi 260W Screen Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to loosen the two clips on the short sides of the Nuvi screen encasing to a position that allows the removal of the screen.
Conclusão
Hunter Johnson
Membro desde: 03/27/18
327 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G5, Harley Spring 2018 Membro de IUPUI, Team S3-G5, Harley Spring 2018
IUPUI-HARLEY-S18S3G5
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 292
