Ir para o conteúdo principal
Garmin Nuvi 260W Circuit Board Replacement
O que você precisa
  1. Garmin Nuvi 260W Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Circuit Board Replacement: passo 2, imagem 1 %32
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Circuit Board Replacement: passo 3, imagem 1 %32 Garmin Nuvi 260W Circuit Board Replacement: passo 3, imagem 2 %32
    • Once screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Circuit Board Replacement: passo 4, imagem 1 %32
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Circuit Board Replacement: passo 5, imagem 1 %32
    • Once the body of the nüvi is separated and the ribbon cable is disconnected, remove the three 1.6mm Phillips #0 screws.
  6. Garmin Nuvi 260W Circuit Board Replacement: passo 6, imagem 1 %32
    • Carefully disconnect the two cables connecting the battery to the motherboard and remove motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Hunter Johnson
Membro desde: 03/27/18
327 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G5, Harley Spring 2018 Membro de IUPUI, Team S3-G5, Harley Spring 2018
IUPUI-HARLEY-S18S3G5
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 426
