Introdução
This guide will walk you through the process of replacing a faulty or broken microphone in your Garmin Nuvi 2597LMT. You may need this guide to replace the microphone if microphone isn't registering any sound input from your voice, it registers partial or muffled input, or you know that it got damaged inside (possibly from water). Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
O que você precisa
Turn your device over so the back is revealed and you can see the screws in the four corners.
Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
2 comentários
Where do I buy a new microphone?
Good question! I think that the mic on my Nuvi 465W "ist kaput", but Garmin does not sell any internal replacement components!
