Ir para o conteúdo principal
Garmin Nuvi 2595LMT LCD Screen Replacement
O que você precisa
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: passo 1, imagem 1 %32
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 2, imagem 1 %32 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 2, imagem 2 %32
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, imagem 1 %32 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, imagem 2 %32 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 3, imagem 3 %32
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: passo 5, imagem 1 %32 Garmin Nuvi 2595LMT LCD Screen Replacement: passo 5, imagem 2 %32
    • Place new screen in proper position, with the ribbon facing downward.
Conclusão
3 comentários
cannot prise open the connector to replace ribbon
norman bayne - Responder
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Responder
Re-seating the ribbon is simply impossible.
daBee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 4,578
