Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Is your mounting device broken or not locking into place? It might be time to replace it with a new one.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Separate the GPS mounting cradle from the mounting device.
    • Separate the GPS mounting cradle from the mounting device.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Gently remove the cradle from GPS device.
    • Gently remove the cradle from GPS device.
    • [Reassembly tip: Place the cradle so that the triangle on the back is facing upwards. Align the GPS and cradle so the inserts and tabs of the GPS are in line with one another.]
  4. Pull the lever on the back of the GPS mount up and remove it from the surface.
    • Pull the lever on the back of the GPS mount up and remove it from the surface.
Conclusão
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 705
