Ir para o conteúdo principal
Introdução
If your Touch Screen is cracked or scratched up, obtain a new Touch Screen and replace the old one with the new Touch Screen.
  1. Remove the barcode sticker at the bottom of the device.
    • Remove the barcode sticker at the bottom of the device.
  2. Remove two 8.4 mm T5 screws from the bottom of the device.
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
    turn the unit around
    Andrew Hayden - Responder
    Since there is no replacement speaker whats the point of this process?
    greg - Responder
    Very detailed set of instructions! Does anyone known the thread size of the screws in step 2? 8.4 mm T5 screws: is the length of the screw (8.4 mm) ,and the head specification (T5- size of screw driver). I need the actual thread specification. I lost one of the screws and the other one 's head is stripped. I need to replace both screws.
    Harold Schultz - Responder
  4. Remove the power button. Remove the power button.
    • Remove the power button.
    Where can I buy the button
    milosvalek - Responder
  5. Remove touch screen by using the plastic opening tool as a wedge to pry the touch screen from the case.
    • Remove touch screen by using the plastic opening tool as a wedge to pry the touch screen from the case.
    • It is easiest to do this by pulling on the side tab as you wedge the touch screen away from the case.
  6. Lift the touch screen above the mother board so that its position is similar to what is shown.
    • Lift the touch screen above the mother board so that its position is similar to what is shown.
    • Remove the tape connecting the gold ribbon cable circuit to the motherboard.
    • Peel the tape off slowly so there won't be any damage to the motherboard or gold ribbon cable.
  7. Lift up the tab connecting the gold ribbon circuit to the motherboard, using a plastic opening tool if necessary. Gently remove the gold ribbon cable.
    • Lift up the tab connecting the gold ribbon circuit to the motherboard, using a plastic opening tool if necessary.
    • Gently remove the gold ribbon cable.
    • To insert a new screen in, attach the gold ribbon circuit to the motherboard by sliding it in place and pressing down on the tab. This may take a few attempts before it is connected successfully.
    The gold ribbon cable must be fully inserted under the flap. If there is no resitance in closing the flap, then it is not inserted all the way. It is difficult and takes patience with a steady hand. The tiny pins on the underside beneath the flap must penetrate the ribbon cable. A good magnifying glass is helpful.
    bluffviewmanor - Responder
Conclusão
6 outras pessoas concluíram este guia.
Ryan
Membro desde: 26/01/2012
137 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 9-3, Regan Winter 2012 Membro de Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membros
4 Guias de autoria
When do i find replacement glass
Denise - Responder
I just purchased an aftermarket touch screen with digitizer on ebay for $17 USD from a Chinese seller. Will update here with item listing # if the item is successfully installed and works.
NunOf YourBiz - Responder
I just got my aftermarket screen today. One thing worth noting is that these aftermarket screens don't have that thin adhesive shock absorbing stuff around the perimeter of the screen and it's impossible to take it off the original screen and reuse it. I used pieces of weather stripping that I cut down thinner. This isn't necessary for it to work, but it helps provide some protection.
I installed it about 3 hours ago and everything seems to work fine. How long it's going to last is another story.
If interested, you can buy the screen from ebay seller mingxing200808 Item # 400709570325. I live in NE USA and amazingly I got my screen in a little over a week after I completed the purchase. Not bad.
BTW: for those that just need the digitizer, you can pick one up on ebay for just a coupe dollars, however I have no idea how hard it would be to remove the old one and replace the new one. Looks like it might be harder than just changing the whole screen+digitizer kit.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 26,003
