Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the barcode sticker at the bottom of the device.
Remove two 8.4 mm T5 screws from the bottom of the device.
Using a plastic opening tool, carefully pry open the device.
Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
Lift up the motherboard.
Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
