Ir para o conteúdo principal
Garmin Nuvi 255W Speaker Replacement
O que você precisa
  1. Garmin Nuvi 255W Speaker Replacement, Power Button: passo 1, imagem 1 %32
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Speaker Replacement: passo 2, imagem 1 %32
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Speaker Replacement: passo 3, imagem 1 %32 Garmin Nuvi 255W Speaker Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Speaker Replacement: passo 4, imagem 1 %32 Garmin Nuvi 255W Speaker Replacement: passo 4, imagem 2 %32
    • Remove the power button.
  5. Garmin Nuvi 255W Speaker Replacement, Battery: passo 5, imagem 1 %32
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Speaker Replacement: passo 6, imagem 1 %32 Garmin Nuvi 255W Speaker Replacement: passo 6, imagem 2 %32
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Speaker Replacement: passo 7, imagem 1 %32 Garmin Nuvi 255W Speaker Replacement: passo 7, imagem 2 %32
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
  8. Garmin Nuvi 255W Speaker Replacement, Speaker: passo 8, imagem 1 %32
    • Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
  9. Garmin Nuvi 255W Speaker Replacement: passo 9, imagem 1 %32 Garmin Nuvi 255W Speaker Replacement: passo 9, imagem 2 %32
    • Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
Conclusão
Timothy
Membro desde: 01/26/12
76 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-3, Regan Winter 2012 Membro de Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 3,996
