Ir para o conteúdo principal
Garmin Nuvi 255W Battery Replacement
O que você precisa
  1. Garmin Nuvi 255W Battery Replacement, Power Button: passo 1, imagem 1 %32
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: passo 2, imagem 1 %32
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: passo 3, imagem 1 %32 Garmin Nuvi 255W Battery Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: passo 4, imagem 1 %32 Garmin Nuvi 255W Battery Replacement: passo 4, imagem 2 %32
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: passo 5, imagem 1 %32
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: passo 6, imagem 1 %32 Garmin Nuvi 255W Battery Replacement: passo 6, imagem 2 %32
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: passo 7, imagem 1 %32 Garmin Nuvi 255W Battery Replacement: passo 7, imagem 2 %32
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Conclusão
15 outras pessoas executaram este guia.
Timothy
Membro desde: 01/26/12
73 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-3, Regan Winter 2012 Membro de Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
Membros da 5
Autoria de 4 guias
9 comentários
Thanks for this very nicely illustrated guide.
RBStorms - Responder
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - Responder
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - Responder
Thanks, great demonstration.
peter2x4 - Responder
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 70
Duração total: 26,799
