Introdução
The tools you will need are a T5 Torx screwdriver, plastic opening tool, and soldering equipment. The speaker might be glued to the back of the device and is connected to the motherboard.
O que você precisa
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Quase terminado!
Conclusão
