Ir para o conteúdo principal
Garmin Nuvi 2557LMT Speaker Replacement
O que você precisa
  1. Garmin Nuvi 2557LMT Speaker Replacement, Garmin Nuvi 2557LMT Disassembly: passo 1, imagem 1 %32
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Speaker Replacement: passo 2, imagem 1 %32
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Speaker Replacement: passo 3, imagem 1 %32
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Speaker Replacement: passo 4, imagem 1 %32 Garmin Nuvi 2557LMT Speaker Replacement: passo 4, imagem 2 %32
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  6. Garmin Nuvi 2557LMT Speaker Replacement: passo 6, imagem 1 %32
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 175
