Ir para o conteúdo principal
Garmin Nuvi 2557LMT Battery Replacement
O que você precisa
  1. Garmin Nuvi 2557LMT Battery Replacement, Garmin Nuvi 2557LMT Disassembly: passo 1, imagem 1 %32
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Battery Replacement: passo 2, imagem 1 %32
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Battery Replacement: passo 3, imagem 1 %32
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Battery Replacement: passo 4, imagem 1 %32 Garmin Nuvi 2557LMT Battery Replacement: passo 4, imagem 2 %32
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Battery Replacement, Battery: passo 5, imagem 1 %32
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Battery Replacement: passo 6, imagem 1 %32
    • Pull the battery-motherboard connector away from the motherboard.
Conclusão
2 comentários
On my Nuvi 2557, the silver name bezel is part of the front cover - it does not separate. I just split the case as shown.
The battery connector pulls out perpendicular to the pc board, and you re-insert it by aligning and pressing down against the board.
john horn - Responder
Would this apply to the Nuvi 2555LMT?
Bill Hines - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,202
