Ir para o conteúdo principal
Garmin Nuvi 2455LMT Speaker Replacement
O que você precisa
  1. Garmin Nuvi 2455LMT Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver. Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Speaker Replacement: passo 2, imagem 1 %32 Garmin Nuvi 2455LMT Speaker Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
  3. Garmin Nuvi 2455LMT Speaker Replacement: passo 3, imagem 1 %32 Garmin Nuvi 2455LMT Speaker Replacement: passo 3, imagem 2 %32 Garmin Nuvi 2455LMT Speaker Replacement: passo 3, imagem 3 %32
    • Open the device carefully being weary of the orange band that is going from the screen to the mother board.
  4. Garmin Nuvi 2455LMT Speaker Replacement: passo 4, imagem 1 %32 Garmin Nuvi 2455LMT Speaker Replacement: passo 4, imagem 2 %32
    • Using the plastic prying tool, carefully pry the speaker from the plastic backing.
    • Remove the speaker from the motherboard by gently pulling on the wire.
Conclusão
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2016 Membro de USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 210
