Ir para o conteúdo principal
Garmin Nuvi 2455LMT Back Panel Assembly Replacement
O que você precisa
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: passo 1, imagem 1 %32
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 2, imagem 1 %32 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, imagem 1 %32 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, imagem 2 %32 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, imagem 3 %32
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
Conclusão
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2016 Membro de USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 974
