Ir para o conteúdo principal
Garmin Nuvi 200w Screen Replacement
O que você precisa
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, imagem 1 %32 Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, imagem 2 %32 Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, imagem 3 %32
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: passo 2, imagem 1 %32
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: passo 3, imagem 1 %32 Garmin Nuvi 200w Screen Replacement: passo 3, imagem 2 %32 Garmin Nuvi 200w Screen Replacement: passo 3, imagem 3 %32
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: passo 4, imagem 1 %32 Garmin Nuvi 200w Screen Replacement: passo 4, imagem 2 %32
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, imagem 1 %32 Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, imagem 2 %32 Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, imagem 3 %32
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: passo 6, imagem 1 %32 Garmin Nuvi 200w Screen Replacement, Screen: passo 6, imagem 2 %32 Garmin Nuvi 200w Screen Replacement, Screen: passo 6, imagem 3 %32
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
Conclusão
Matthew Eires
Membro desde: 03/08/17
319 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 348
