Ir para o conteúdo principal
Garmin Nuvi 200W Rear Cover Replacement
O que você precisa
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, imagem 1 %32 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, imagem 2 %32 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, imagem 3 %32
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: passo 2, imagem 1 %32
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: passo 3, imagem 1 %32 Garmin Nuvi 200W  Rear Cover Replacement: passo 3, imagem 2 %32 Garmin Nuvi 200W  Rear Cover Replacement: passo 3, imagem 3 %32
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: passo 4, imagem 1 %32 Garmin Nuvi 200W  Rear Cover Replacement: passo 4, imagem 2 %32
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
Conclusão
Matthew Eires
Membro desde: 03/08/17
319 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 249
