Ir para o conteúdo principal
Garmin Nuvi 200 Display Replacement
O que você precisa
  1. Garmin Nuvi 200 Display Replacement, Rear Casing: passo 1, imagem 1 %32 Garmin Nuvi 200 Display Replacement, Rear Casing: passo 1, imagem 2 %32
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Display Replacement: passo 2, imagem 1 %32
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Display Replacement: passo 3, imagem 1 %32 Garmin Nuvi 200 Display Replacement: passo 3, imagem 2 %32
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Display Replacement, Display: passo 4, imagem 1 %32
    • Apply pressure to the tabs holding the screen in place with the plastic opening tool
  5. Garmin Nuvi 200 Display Replacement: passo 5, imagem 1 %32 Garmin Nuvi 200 Display Replacement: passo 5, imagem 2 %32
    • Apply pressure to the same tabs again to remove the front of the screen.
  6. Garmin Nuvi 200 Display Replacement: passo 6, imagem 1 %32 Garmin Nuvi 200 Display Replacement: passo 6, imagem 2 %32
    • Peel away the material holding the ribbon cable in place.
    • Peeling the sticker halfway will allow you to access the ribbon cable. Removing it fully will allow you to detach the upper case from the lower case.
  7. Garmin Nuvi 200 Display Replacement: passo 7, imagem 1 %32 Garmin Nuvi 200 Display Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon cable from the logic board.
    • Make sure to disconnect the cable from both ports.
  8. Garmin Nuvi 200 Display Replacement: passo 8, imagem 1 %32 Garmin Nuvi 200 Display Replacement: passo 8, imagem 2 %32
    • The display consists of two screens which are held together by the ribbon.
Conclusão
4 outras pessoas executaram este guia.
Nick
Membro desde: 04/11/10
7 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 25-90, Amido Spring 2010 Membro de Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 10,970
