Ir para o conteúdo principal
Garmin Nuvi 1490T Speaker Replacement
O que você precisa
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: passo 1, imagem 1 %32
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: passo 2, imagem 1 %32
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: passo 3, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement: passo 3, imagem 2 %32
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, imagem 2 %32 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, imagem 3 %32
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: passo 5, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement: passo 5, imagem 2 %32 Garmin Nuvi 1490T Speaker Replacement: passo 5, imagem 3 %32
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: passo 6, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: passo 7, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: passo 8, imagem 1 %32 Garmin Nuvi 1490T Speaker Replacement: passo 8, imagem 2 %32 Garmin Nuvi 1490T Speaker Replacement: passo 8, imagem 3 %32
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
Conclusão
Ricardo Solis
Membro desde: 01/20/16
1.037 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 15-2, Remmell Spring 2016 Membro de USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 273
