Introdução
Use this guide to replace the battery of your Garmin Nuvi 1490T GPS.
O que você precisa
Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
Ferramenta utilizada nesse passo:Tweezers$4.99
Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
Gently disconnect the display by pulling upward. Set display aside.
Using the T5 Torx screw driver, remove the two 5.0 mm screws.
Using your hands, lift up the motherboard and fold it over.
7 outras pessoas executaram este guia.
2 comentários
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Thanks for the great instructions! Had I not given up on Garmin's video instruction I'm sure I would have destroyed my GPS. You saved the day for me. Again, THANKS!
