Ir para o conteúdo principal
Garmin Nuvi 1390LMT Logic Board Replacement
O que você precisa
  1. Garmin Nuvi 1390LMT Logic Board Replacement, Logic Board: passo 1, imagem 1 %32
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Logic Board Replacement: passo 2, imagem 1 %32 Garmin Nuvi 1390LMT Logic Board Replacement: passo 2, imagem 2 %32
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Logic Board Replacement: passo 3, imagem 1 %32
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Logic Board Replacement: passo 4, imagem 1 %32
    • Gently pull the wire ribbon connecting the screen to the logic board from the plug.
    • Be careful when unplugging the wire ribbon. It is very fragile.
  5. Garmin Nuvi 1390LMT Logic Board Replacement: passo 5, imagem 1 %32
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Logic Board Replacement: passo 6, imagem 1 %32
    • Flip the logic board over.
  7. Garmin Nuvi 1390LMT Logic Board Replacement: passo 7, imagem 1 %32 Garmin Nuvi 1390LMT Logic Board Replacement: passo 7, imagem 2 %32
    • Disconnect the harness between the battery and the logic board.
Conclusão
Trey Ulsh
Membro desde: 10/22/15
537 Reputação
Autoria de 3 guias
Equipe
Montana Tech, Team 10-4, Shirk Fall 2015 Membro de Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
Membros da 5
Autoria de 3 guias
Um comentário
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
Danny - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 930
