Ir para o conteúdo principal
Garmin Nuvi 1390LMT Battery Replacement
O que você precisa
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: passo 1, imagem 1 %32
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: passo 2, imagem 1 %32 Garmin Nuvi 1390LMT Battery Replacement: passo 2, imagem 2 %32
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: passo 3, imagem 1 %32
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: passo 4, imagem 1 %32 Garmin Nuvi 1390LMT Battery Replacement: passo 4, imagem 2 %32
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: passo 5, imagem 1 %32
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: passo 6, imagem 1 %32 Garmin Nuvi 1390LMT Battery Replacement: passo 6, imagem 2 %32
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: passo 7, imagem 1 %32
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: passo 8, imagem 1 %32 Garmin Nuvi 1390LMT Battery Replacement: passo 8, imagem 2 %32
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Linha de Chegada
3 outras pessoas executaram este guia.
Trey Ulsh
Membro desde: 10/22/15
537 Reputação
Autoria de 3 guias
Equipe
Montana Tech, Team 10-4, Shirk Fall 2015 Membro de Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
Membros da 5
Autoria de 3 guias
Um comentário
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 3,758
