Ir para o conteúdo principal
Garmin Nüvi 52LM Battery Replacement
O que você precisa
  1. Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: passo 1, imagem 1 %32 Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: passo 1, imagem 2 %32
    • Place the device face-down, with the screen facing the surface. There are 8.7mm screws located in each of the back 4 corners of the device. Using a T5 Torx screw bit, unscrew all four screws and leave them aside.
  2. Garmin Nüvi 52LM Battery Replacement: passo 2, imagem 1 %32 Garmin Nüvi 52LM Battery Replacement: passo 2, imagem 2 %32
    • Place a plastic opening tool in the seam between the back and front plates of the device. Using constant pressure, slowly and continuously slide the tool along the seam. The tool should disable each of the hooks holding the two plates together. If unsuccessful, apply slightly more pressure and try again.
    • Once all hooks are disabled, slowly separate the two plates, being careful not to damage the ribbon wire still connecting the two.
  3. Garmin Nüvi 52LM Battery Replacement, Battery: passo 3, imagem 1 %32 Garmin Nüvi 52LM Battery Replacement, Battery: passo 3, imagem 2 %32
    • Using the T5 Torx screwdriver, unscrew the two 5.6mm screws at the top right and bottom right corners of the motherboard.
  4. Garmin Nüvi 52LM Battery Replacement: passo 4, imagem 1 %32 Garmin Nüvi 52LM Battery Replacement: passo 4, imagem 2 %32
    • Gently unplug the wire connecting the battery to the small socket on the back of the motherboard.
  5. Garmin Nüvi 52LM Battery Replacement: passo 5, imagem 1 %32 Garmin Nüvi 52LM Battery Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, pry the battery from the back cover of the device. There may be an adhesive sticker keeping it in place, so you may need to apply some force.
    • The battery should now be completely detached from the other parts.
Conclusão
Uma outra pessoa concluiu este guia.
Camron Dennler
Membro desde: 01/24/17
146 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-1, Banghart Winter 2017 Membro de Cal Poly, Team 10-1, Banghart Winter 2017
CPSU-BANGHART-W17S10G1
Membros da 4
Autoria de 5 guias
Um comentário
I was told the small connector at the back of my device is the problem. I am thinking it may be the battery. I don’t really want to throw my gps away if I can fix it! Thanks!
gsolomon77 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 2,266
