Introdução
In dieser Anleitung wird gezeigt wie man den Akku des Garmin Nüvi 200 austauscht.
O que você precisa
Ziehe den Aufkleber auf der Unterseite ab um an zwei Schrauben zu gelangen.
Ziehe das Klebeband ab, das die Flachbandkabel abdeckt.
Klappe den Sicherungsbügel am ZIF-Anschluss des Flachbandkabels mit dem Spudger hoch. Löse dann vorsichtig das Kabel ab.
Um das Gerät zusammenzusetzen befolge die Schritte in umgekehrter Reihenfolge.
18 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
13 comentários
This document could be improved by including information about where to acquire a replacement battery, and any modifications that might be required to a generic battery.
Seems like there are some on Amazon and Ebay. Not sure how to verify getting the right one. Not that expensive, so maybe worth the risk.
It was a huge mistake to peel away the ribbon cable. It needs matched up precisely and exactly in the same alignment as it was before during reassembly, an apparently impossible task once it's been detached. I'd advise opening the halves in book form, leaving the ribbon cable as a hinge. Have about given up trying to position it.
Nice tutorial, except for the booby trap.
Yep, fell into this trap, too. The Nuvi powers up but no video. Can't place the ribbon cabe just exactly so. Ugh.
Cannot stress enough that the step 5 calling for the removal of the tape holding the ribbon cable be removed from this guide! My Nuvi will not work anymore because I can't get that ribbon cable aligned. I wish I had read all the comments as the above poster warned of this very problem. Please update the guide and remove step 5!
