Ir para o conteúdo principal
Garmin GPSmap 60CSx Keypad Buttons Replacement
O que você precisa
  1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: passo 1, imagem 1 %32
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 2, imagem 1 %32
    • Lift battery release up to remove battery cover.
    Pergunte ao FixBot
    Comentar
  3. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 3, imagem 1 %32 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 3, imagem 2 %32
    • Pull AA batteries out.
    Pergunte ao FixBot
    Comentar
  4. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: passo 4, imagem 1 %32 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: passo 4, imagem 2 %32
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
    Pergunte ao FixBot
    Comentar
  5. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 5, imagem 1 %32
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
    Pergunte ao FixBot
    Comentar
  6. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 6, imagem 1 %32 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 6, imagem 2 %32
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
    Pergunte ao FixBot
    Comentar
  7. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 7, imagem 1 %32 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 7, imagem 2 %32
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 3,311
