Introdução
One of the main reasons we would replace a button pad is if the functions are not working properly or at all. The functions could be getting stuck if that is the case then the button pad will need to be replaced. Some of the tools needed to replace the button pad are a Phillips screwdriver, soldering iron, soldering wire, and a pair of tweezers. Some soldering skills will be needed to perform this repair.
O que você precisa
Orient the GPS V backside up.
With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
3 outras pessoas executaram este guia.
Um comentário
Hey, a have an old Garmin GPS III and my problem is that the GPS can not find any satelliters. I have opened back plate and I think its looks ok inside.
What can I do?
Best regards
Christian Tregert
Ctregert@hotmail.com
