Ir para o conteúdo principal
Garmin Forerunner 25 Motherboard Replacement
O que você precisa
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: passo 2, imagem 1 %32
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: passo 5, imagem 1 %32
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Dustin Persohn
Membro desde: 03/21/18
235 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S5-G3, Baechle Spring 2018 Membro de IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 891
