Ir para o conteúdo principal
Garmin Forerunner 25 Battery Replacement
O que você precisa
  1. Garmin Forerunner 25 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: passo 2, imagem 1 %32
    • Pry the old battery out using a plastic spudger.
Conclusão
Uma outra pessoa concluiu este guia.
Dustin Persohn
Membro desde: 03/21/18
235 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S5-G3, Baechle Spring 2018 Membro de IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
Membros da 3
Autoria de 5 guias
11 comentários
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Responder
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Responder
Just look at the last picture. PD2430C1
Leandro Lind - Responder
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Responder
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 105
Duração total: 6,071
