Introdução
The manufacturer indicates that this watch is not user replaceable. However, this guide provides easy instructions to follow for replacing the battery of your Garmin Forerunner 10. No previous skills are needed for this moderately easy replacement.
Ferramentas
Peças
Use the Torx 5 Screwdriver to remove all four 1.1 mm screws on the back of the watch.
To reassemble the watch, follow these instructions in reverse order. Charge your watch when finished. Check to make sure all features are working.
11 outras pessoas concluíram este guia.
8 comentários
Thanks you for sharing. Easy enough to follow. A bit fiddly but took my time and made sure I had a small box to keep the bits in while I waited for the new battery to arrive. One of the springs did pop out (Step 2) but I didn’t lose it!! Reassembled and the watch turns on so all looking good! I think my old battery leaked so I am hoping no internal damage was done and the watch can recharge the new battery.
Also works on the Garmin Forerunner 15
Extra hints:
Step 2 - The red seal can come out with the back - carefully place it back into its slot in the body of the watch before reassembly. It only goes in one way. Not sure about turning it over to be ‘face up’ as the springs will fall out. Move onto step 3 and tape them, etc.
Step 3 - you can tape the springs, but when the motherboard is removed, they can fall out the back. Consider carefully removing them first and setting aside in the matching pattern for easy replacement
Steps 4-6 - all good, but don’t bend those metal clips too much…
Step 7 - consider taking the tape off the front of the battery (+ side) as well and moving to the new one
Step 8 - reassembly of motherboard - carefully compress each corner and feel as each clip ‘clicks’ back into place
Step 9 - place back in housing, making sure it sits level
Step 10 - replace back of watch - a few careful jiggles may be required as there are 6 different springs to get touching at the right places.
