Ir para o conteúdo principal
Garmin Fenix 5 Cleaning
O que você precisa
  1. Garmin Fenix 5 Cleaning, Front screws: passo 1, imagem 1 %32 Garmin Fenix 5 Cleaning, Front screws: passo 1, imagem 2 %32
    • Remove the strap
    • Power-off the device
    • Remove the screws on the front using the Torx T4 screwdriver
  2. Garmin Fenix 5 Cleaning, Rear screws: passo 2, imagem 1 %32
    • Remove the screws on the rear using the Torx T6 (or TR6) screwdriver
  3. Garmin Fenix 5 Cleaning, The small arc: passo 3, imagem 1 %32 Garmin Fenix 5 Cleaning, The small arc: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the small grey arc on the top of the device with the tweezers
  4. Garmin Fenix 5 Cleaning, Remove the screen: passo 4, imagem 1 %32
    • With the tweezers, remove the pin connector linked to the screen
    • Remove the screen
  5. Garmin Fenix 5 Cleaning, Free the motherboard: passo 5, imagem 1 %32 Garmin Fenix 5 Cleaning, Free the motherboard: passo 5, imagem 2 %32
    • Remove the 2 screws on the motherboard using the PH #000 screwdriver
    What size are these screws? I need a replacement ._."
    Dante Horatio - Responder
    Pero después de el desarme no necesita un sellado especial?
    Felipe A. - Responder
  6. Garmin Fenix 5 Cleaning, The sensor: passo 6, imagem 1 %32 Garmin Fenix 5 Cleaning, The sensor: passo 6, imagem 2 %32
    • Remove the 2 screws holding the sensor between the buttons on the right side of the case
    • With the tweezers, remove the sensor and detach the case from the motherboard
  7. Garmin Fenix 5 Cleaning, Gasket and buttons: passo 7, imagem 1 %32 Garmin Fenix 5 Cleaning, Gasket and buttons: passo 7, imagem 2 %32 Garmin Fenix 5 Cleaning, Gasket and buttons: passo 7, imagem 3 %32
    • Remove the seal around the circumference of the watch casing, as you will be handling the casing a lot and you don’t want to risk tearing the gasket.
    • Using the tweezers, remove the circlips around every button very carefully.
    • When the circlips are removed, you can pull the buttons off. Do this step carefully because you will also find a return spring inside every button hole
    Beware of losing the circlips especially during reinstall. Replacements are $10 USD/50 count. See below.
  8. Garmin Fenix 5 Cleaning, Clean case and buttons: passo 8, imagem 1 %32
    • Clean the case, including the hole of the buttons
    • Clean the buttons and the springs
    • (OPTIONAL) You can lubrificate the buttons before re-inserting them in the case
    • Reassemble the watch
    I have a 5X that needs the battery replaced. it would be great to add the battery replacement to this guide! any chance you could do this ? I purchased the battery already and am ready to do this. Garmin says too bad too sad my device is "end of life" I simply refuse to believe that. It's a $800 device and although it's old(ish) the only thing wrong is the battery.
    Samuel Prokop - Responder
    I Samuel,
    Unfortunately, I don't have a Garmin 5X but I've found a video on YouTube that can help you replace the battery: How to replace your aging Garmin Fenix 5X Battery
    Garmin Boy -
    What is the best lubricant for the buttons? I'm leaning toward a silicone spray, but that may not be too durable.
    I decided on graphite so it won't gum up and can be easily powered in to reapply.
    Dante Horatio -
    Buenas tardes, me ocurre este problema con mi Garmin fénix 6x saphire. El procedimiento sería el mismo?
    Jose Antonio Cordero Hernandez - Responder
    Hola buenos, en caso de haber perdido uno de los tornillos de la parte delantera del cristal como o donde puedo reemplazarlo? Gracias!
    Erik - Responder
Conclusão
6 outras pessoas executaram este guia.
Garmin Boy
Membro desde: 04/28/21
304 Reputação
Autoria de 1 guia
13 comentários
Thanks for that info. In looking at the pictures, I can’t tell which piece is the battery. Do you think it can be easily replaced? Or is it soldered in? Thanks.
Patrick Chang - Responder
Hi,
the battery is visible in the step 5 and step 6.
It is linked to the mainborad with a connector, It’s not soldered.
It’s glued to the back cover but, in my opinion, it can be easy replaced.
The battery type is "361-00097-00"
The nominal specifications are 255mAh, 0.97Wh and 3.8V
On ebay you can find a new battery: https://www.ebay.it/itm/283519139846?has...
I hope this can help
Garmin Boy -
Maybe do You know where to purchase a gaskets?
Edgaras Tamošauskas - Responder
Unfortunately, I don’t know where you can find it.
I’ve searched on my favourite websites with no luck.
Garmin Boy -
Question: do I need to disasassemble the screen to change only the battery? Can I just access to it by the rear cover?
Thanks for the info!
Cristóbal Sabroe Yde - Responder
Hi,
Yes, I think you can remove only the rear cover.
But if your watch is 2-3 years old, I think that cleaning everything it’s worth it.
^_^
Garmin Boy -
Anyone that has done a tear down of Fenix 6? The vibration module is loose and would be good to see if it can be glued back.
Ludde Algell - Responder
Hello, thank you for the article. Is there anyway to clean the button on the motherboard (especially when oxidized)? Some sort of solution or lubricant? I think some seawater snuck into the case (through the button) while pressing the back button under water. I followed your steps to de-assemble the watch and I think the button is somehow stuck, resulting in a kind of random/continuous activity. Thank you. Jacopo
Jacopo De Santa - Responder
Hi Jacopo,
I suggest cleaning it with isopropyl alcohol or rubbing alcohol. Another solution is to use a mixture of baking soda and water. You can apply the solution using a small paintbrush.
Garmin Boy -
Beware of the circlips: They are easy to lose. (Whoops. Twice.) I bought a replacement here (the 1/8" stainless steel): https://www.mcmaster.com/catalog/130/374...
CORRECTION: Buy the 1/16" size! Then, crimp them before fitting them back on the shaft of the button so they are tight.
Dante Horatio -
The screen of my garmin fenix 5s plus is malfunctioning. It displays horizontal lines only. Do you know if can be repaired?
Jes - Responder
Hi Jes.
Unfortunately, I don't have this information.
However, I think that I'll probably have to change the screen.
Garmin Boy -
Comentar
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 87
Últimos 30 dias: 394
Ao todo: 15,664
