Ir para o conteúdo principal
Garmin Fenix 3 Motherboard Replacement
O que você precisa
  1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: passo 1, imagem 1 %32 Garmin Fenix 3 Motherboard Replacement, Display Assembly: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Motherboard Replacement: passo 3, imagem 1 %32
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Motherboard Replacement: passo 4, imagem 1 %32
    • Set the watch face aside.
  5. Garmin Fenix 3 Motherboard Replacement, GPS Antenna: passo 5, imagem 1 %32
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 Motherboard Replacement: passo 6, imagem 1 %32
    • Carefully remove the antenna, and set it aside.
  7. Garmin Fenix 3 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Garmin Fenix 3 Motherboard Replacement, Motherboard: passo 7, imagem 2 %32 Garmin Fenix 3 Motherboard Replacement, Motherboard: passo 7, imagem 3 %32
    • Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
  8. Garmin Fenix 3 Motherboard Replacement: passo 8, imagem 1 %32 Garmin Fenix 3 Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
  9. Garmin Fenix 3 Motherboard Replacement: passo 9, imagem 1 %32
    • Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
  10. Garmin Fenix 3 Motherboard Replacement: passo 10, imagem 1 %32
    • Motherboard without metal cover
Conclusão
6 outras pessoas executaram este guia.
15 comentários
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Jan Stefan - Responder
How did you remove the metal cover from the moterboard (last picture)
slowrun - Responder
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
arnaud.lhote - Responder
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
ilija.veselica -
In Italy it’s the same story… impossible to repair ( button START/STOP does not function ).
I’m searching on eBay for a USED low cost Fenix 3 for change motherboard…
At the moment is the unic solutions…
Matteo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 89
Duração total: 8,766
