Ir para o conteúdo principal
Garmin Fenix 3 HR Motherboard Replacement
O que você precisa
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: passo 2, imagem 1 %32 Garmin Fenix 3 HR Motherboard Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: passo 4, imagem 1 %32 Garmin Fenix 3 HR Motherboard Replacement: passo 4, imagem 2 %32
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: passo 5, imagem 1 %32
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: passo 6, imagem 1 %32
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: passo 7, imagem 1 %32
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: passo 8, imagem 1 %32
    • Now attach battery to new motherboard and reassemble.
Conclusão
5 outras pessoas executaram este guia.
Jacob Smiley
Membro desde: 03/26/18
277 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G6, Harley Spring 2018 Membro de IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
Membros da 3
Autoria de 4 guias
2 comentários
And where would one source replacement motherboard?
jonathan.hatchuel - Responder
donde puedo encontras placa.madre reeemplazo????
luis zavala - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 4,752
