Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Garmin Fenix 3 HR Battery Replacement
O que você precisa
  1. Garmin Fenix 3 HR Battery Replacement, Battery: passo 1, imagem 1 %32 Garmin Fenix 3 HR Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: passo 2, imagem 1 %32 Garmin Fenix 3 HR Battery Replacement: passo 2, imagem 2 %32 Garmin Fenix 3 HR Battery Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: passo 3, imagem 1 %32
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: passo 4, imagem 1 %32 Garmin Fenix 3 HR Battery Replacement: passo 4, imagem 2 %32
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: passo 5, imagem 1 %32
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: passo 6, imagem 1 %32
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: passo 7, imagem 1 %32
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: passo 8, imagem 1 %32
    • Now attach the new battery with adhesive and reassemble.
Conclusão
40 outras pessoas executaram este guia.
Victor Tanguy
Membro desde: 03/26/18
1.329 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G6, Harley Spring 2018 Membro de IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
Membros da 3
Autoria de 4 guias
29 comentários
Does anybody do It in a fenix 5?
Fernando Alcaraz - Responder
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Responder
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 93
Últimos 30 dias: 467
Duração total: 65,757
