Introdução
If your GPS is failing to find your location, lags, or performs oddly, you can use this guide to locate and replace the antenna, which is located inside the watch. To do this, you will need a T6 Torx screwdriver and a spudger. Tweezers are best used for extracting the GPS antenna.
O que você precisa
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Uma outra pessoa concluiu este guia.
8 comentários
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
Hi did you find gps antenna
