Ir para o conteúdo principal
Garmin Fenix 3 Display Assembly Replacement
O que você precisa
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: passo 2, imagem 1 %32
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: passo 4, imagem 1 %32
    • Set the watch face aside.
Conclusão
6 outras pessoas executaram este guia.
4Comentários do guia
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Responder
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - Responder
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
Abdullah - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 65
Ao todo: 10,382
