Introdução
If you find yourself on this guide, it means that you are having problems attaching your Garmin Edge 830 to its respective mount. The best solution to this is to replace the back cover . In order to do this you will have to take the device apart in its entirety. This may sound like a lot of work, but we have attached all the required steps that will have you done in a timely manner. Make sure you keep track of all your parts/screws along the way.
O que você precisa
Passo 1 Touch Display
Cuidado: as etapas de 1 a 3 são provenientes de um guia marcado como em andamento.
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Passo 4 Motherboard
Cuidado: as etapas de 4 a 7 são provenientes de um guia marcado como em andamento.
Ferramenta utilizada nesse passo:Tweezers$3.99-
Remove brown and green tape with angled tweezers
Passo 8 Battery
Cuidado: a etapa 8 é proveniente de um guia marcado como em andamento.
Use the halberd spudger to lift and remove the battery from the back cover.
Once all previous steps are completed, you will be left with the back cover.
Uma outra pessoa concluiu este guia.
Um comentário
What are the steps required to put the screen back on? What glue should we use and how?
