Ir para o conteúdo principal
Garmin Edge 530 Back Cover Replacement
O que você precisa
  1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: passo 1, imagem 1 %32
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
    Pergunte ao FixBot
  2. Garmin Edge 530 Back Cover  Replacement: passo 2, imagem 1 %32 Garmin Edge 530 Back Cover  Replacement: passo 2, imagem 2 %32 Garmin Edge 530 Back Cover  Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    Pergunte ao FixBot
  3. Garmin Edge 530 Back Cover  Replacement: passo 3, imagem 1 %32 Garmin Edge 530 Back Cover  Replacement: passo 3, imagem 2 %32 Garmin Edge 530 Back Cover  Replacement: passo 3, imagem 3 %32
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    Pergunte ao FixBot
  4. Garmin Edge 530 Back Cover  Replacement: passo 4, imagem 1 %32
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    Pergunte ao FixBot
  5. Garmin Edge 530 Back Cover  Replacement, Motherboard: passo 5, imagem 1 %32 Garmin Edge 530 Back Cover  Replacement, Motherboard: passo 5, imagem 2 %32
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    Pergunte ao FixBot
  6. Garmin Edge 530 Back Cover  Replacement: passo 6, imagem 1 %32
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    Pergunte ao FixBot
  7. Garmin Edge 530 Back Cover  Replacement: passo 7, imagem 1 %32 Garmin Edge 530 Back Cover  Replacement: passo 7, imagem 2 %32
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
    Pergunte ao FixBot
  8. Garmin Edge 530 Back Cover  Replacement: passo 8, imagem 1 %32 Garmin Edge 530 Back Cover  Replacement: passo 8, imagem 2 %32 Garmin Edge 530 Back Cover  Replacement: passo 8, imagem 3 %32
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
    Pergunte ao FixBot
  9. Garmin Edge 530 Back Cover  Replacement, Back Cover: passo 9, imagem 1 %32
    • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
    • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
    Pergunte ao FixBot
Conclusão
Equipe
Clemson, Team 2-1, Hunter Spring 2022 Membro de Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 157
Ao todo: 5,582
