Ir para o conteúdo principal
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
O que você precisa
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: passo 1, imagem 1 %32 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: passo 1, imagem 2 %32
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: passo 2, imagem 1 %32 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: passo 2, imagem 2 %32
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, imagem 1 %32 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, imagem 2 %32 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, imagem 3 %32
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,567
