Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
To replace the screen in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement screen. Be sure to have a large workspace to avoid mishandling or damaging the device components.
  1. Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device. Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Remove the back panel using the metal spudger tool. The metal spudger tool can cause damage to internal components. Flip the device over with the screen facing upward and open the device.
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard. Lift the screen and orange ribbon away from the motherboard. The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  5. Carefully unsnap the plastic border surrounding the screen. Carefully unsnap the plastic border surrounding the screen.
    • Carefully unsnap the plastic border surrounding the screen.
Conclusão
yuanhao zu
Membro desde: 30-01-2017
112 Reputação
Autoria de 1 guia
equipe
Baylor, Team 3-3, Whitney Spring 2017 Membro de Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Membros
3 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 266
