Ir para o conteúdo principal
Garmin Drive 52 and Traffic Speaker Replacement
O que você precisa
  1. Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: passo 1, imagem 1 %32 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: passo 1, imagem 2 %32 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: passo 1, imagem 3 %32
    • Pop the suction cup off of the device.
    • Unscrew the four T5 Torx screws on the back.
    • Carefully pry apart the front and back with a Jimmy.
  2. Garmin Drive 52 and Traffic Speaker Replacement: passo 2, imagem 1 %32
    • With the top in hand, carefully apply pressure on the top of the screen to pop it out of the front of the case.
  3. Garmin Drive 52 and Traffic Speaker Replacement: passo 3, imagem 1 %32 Garmin Drive 52 and Traffic Speaker Replacement: passo 3, imagem 2 %32
    • Remove the four Torx T5 screws.
    • Unplug the two connectors from the motherboard and lift it up and out.
  4. Garmin Drive 52 and Traffic Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Gently lift the speaker out.
Conclusão
Jason Wilson
Membro desde: 10/26/22
388 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Membro de UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
Membros da 6
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 93
