Ir para o conteúdo principal
Garmin Drive 52 and Traffic Battery Replacement
O que você precisa
  1. Garmin Drive 52 and Traffic Battery Replacement, Battery: passo 1, imagem 1 %32 Garmin Drive 52 and Traffic Battery Replacement, Battery: passo 1, imagem 2 %32 Garmin Drive 52 and Traffic Battery Replacement, Battery: passo 1, imagem 3 %32
    • Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
    • If necessary, use a Jimmy or other pry tool to open the backside of the device.
  2. Garmin Drive 52 and Traffic Battery Replacement: passo 2, imagem 1 %32 Garmin Drive 52 and Traffic Battery Replacement: passo 2, imagem 2 %32 Garmin Drive 52 and Traffic Battery Replacement: passo 2, imagem 3 %32
    • Once the back side is open, flip the ZIF connector's lock bar up then remove the connector.
  3. Garmin Drive 52 and Traffic Battery Replacement: passo 3, imagem 1 %32 Garmin Drive 52 and Traffic Battery Replacement: passo 3, imagem 2 %32 Garmin Drive 52 and Traffic Battery Replacement: passo 3, imagem 3 %32
    • Use a T5 Torx screwdriver to unscrew the four screws securing the motherboard.
    • Gently detach the wiring from the motherboard and left the motherboard out.
    • Use a nylon spudger to gently lift the battery out.
    • Avoid using metal spudgers near batteries; puncturing or excessively warping batteries can be dangerous.
Conclusão
Jason Wilson
Membro desde: 10/26/22
388 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Membro de UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
Membros da 6
Autoria de 4 guias
Um comentário
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
Chris Massey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 49
Duração total: 894
