Ir para o conteúdo principal
Garmin Dezl 770LMT Speaker Replacement
O que você precisa
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: passo 1, imagem 1 %32 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: passo 1, imagem 2 %32
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: passo 2, imagem 1 %32
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: passo 3, imagem 1 %32
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: passo 4, imagem 1 %32 Garmin Dezl 770LMT Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: passo 5, imagem 1 %32 Garmin Dezl 770LMT Speaker Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Conclusão
Francisco Rosado
Membro desde: 10/05/16
370 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Lacy Fall 2016 Membro de USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
Membros da 4
Autoria de 5 guias
2 comentários
do u know where i can get a replacement speaker
markrushforth65 - Responder
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,014
