O que você precisa
Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
3 outras pessoas executaram este guia.
