Ir para o conteúdo principal
Garmin Dezl 770LMT Screen Replacement
O que você precisa
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: passo 1, imagem 1 %32 Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: passo 1, imagem 2 %32
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Screen Replacement: passo 2, imagem 1 %32
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Screen Replacement: passo 3, imagem 1 %32
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Screen Replacement, Screen: passo 4, imagem 1 %32 Garmin Dezl 770LMT Screen Replacement, Screen: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Screen Replacement: passo 5, imagem 1 %32 Garmin Dezl 770LMT Screen Replacement: passo 5, imagem 2 %32 Garmin Dezl 770LMT Screen Replacement: passo 5, imagem 3 %32
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
  6. Garmin Dezl 770LMT Screen Replacement: passo 6, imagem 1 %32
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
Conclusão
3 outras pessoas executaram este guia.
Aleem Waris
Membro desde: 10/10/16
146 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Lacy Fall 2016 Membro de USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 2,892
