Ir para o conteúdo principal
Garmin Dezl 770LMT Battery Replacement
O que você precisa
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: passo 1, imagem 1 %32 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: passo 1, imagem 2 %32
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: passo 2, imagem 1 %32
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: passo 3, imagem 1 %32
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, imagem 1 %32 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, imagem 2 %32 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, imagem 3 %32
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: passo 5, imagem 1 %32 Garmin Dezl 770LMT Battery Replacement: passo 5, imagem 2 %32
    • Grasp the wire near the mother board and gently lift to detach the battery.
Conclusão
5 outras pessoas executaram este guia.
Francisco Rosado
Membro desde: 10/05/16
370 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Lacy Fall 2016 Membro de USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 6,055
