Introdução
This guide will show you how to properly remove the speaker from your Garmin without damaging the other components.
O que você precisa
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
Slide the metal probe underneath the speaker and pry upwards.
Quase terminado!
Conclusão
