Ir para o conteúdo principal
Garmin Dezl 760LMT Screen Replacement
O que você precisa
  1. Garmin Dezl 760LMT Screen Replacement, Back Panel: passo 1, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Screen Replacement: passo 2, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement: passo 2, imagem 2 %32 Garmin Dezl 760LMT Screen Replacement: passo 2, imagem 3 %32
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Screen Replacement: passo 3, imagem 1 %32
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: passo 4, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: passo 4, imagem 2 %32
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Screen Replacement: passo 5, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Screen Replacement, Screen: passo 6, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement, Screen: passo 6, imagem 2 %32
    • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
  7. Garmin Dezl 760LMT Screen Replacement: passo 7, imagem 1 %32 Garmin Dezl 760LMT Screen Replacement: passo 7, imagem 2 %32 Garmin Dezl 760LMT Screen Replacement: passo 7, imagem 3 %32
    • Turn the screen over so that it is facing upwards.
    • Remove the front plate of the screen.
    • Lift the screen from its back casing.
Conclusão
Ryan Williams
Membro desde: 09/28/16
763 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membro de USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
Membros da 4
Autoria de 6 guias
2 comentários
where can one by the replacement screen
tempestrogue - Responder
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,299
