Ir para o conteúdo principal
Garmin Dezl 760LMT Motherboard Replacement
O que você precisa
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: passo 2, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement: passo 2, imagem 2 %32 Garmin Dezl 760LMT Motherboard Replacement: passo 2, imagem 3 %32
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: passo 3, imagem 1 %32
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: passo 4, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: passo 4, imagem 2 %32
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: passo 5, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: passo 7, imagem 1 %32 Garmin Dezl 760LMT Motherboard Replacement: passo 7, imagem 2 %32 Garmin Dezl 760LMT Motherboard Replacement: passo 7, imagem 3 %32
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
Conclusão
Ryan Williams
Membro desde: 09/28/16
763 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membro de USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
Membros da 4
Autoria de 6 guias
2 comentários
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - Responder
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 2,841
