Ir para o conteúdo principal
Garmin Dezl 760LMT Battery Replacement
O que você precisa
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: passo 1, imagem 1 %32 Garmin Dezl 760LMT Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: passo 2, imagem 1 %32 Garmin Dezl 760LMT Battery Replacement: passo 2, imagem 2 %32 Garmin Dezl 760LMT Battery Replacement: passo 2, imagem 3 %32
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: passo 3, imagem 1 %32
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: passo 4, imagem 1 %32 Garmin Dezl 760LMT Battery Replacement, Battery: passo 4, imagem 2 %32
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: passo 5, imagem 1 %32 Garmin Dezl 760LMT Battery Replacement: passo 5, imagem 2 %32
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
Conclusão
6 outras pessoas executaram este guia.
Ryan Williams
Membro desde: 09/28/16
763 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 4-2, Passmore Fall 2016 Membro de USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
Membros da 4
Autoria de 6 guias
2 comentários
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - Responder
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 5,889
