Ir para o conteúdo principal
Garmin Dash Cam 20 Screen Replacement
O que você precisa
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: passo 1, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: passo 1, imagem 2 %32
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: passo 2, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 2, imagem 2 %32
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: passo 3, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 3, imagem 2 %32
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: passo 4, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 4, imagem 2 %32
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: passo 5, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 5, imagem 2 %32 Garmin Dash Cam 20 Screen Replacement: passo 5, imagem 3 %32
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: passo 6, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 6, imagem 2 %32 Garmin Dash Cam 20 Screen Replacement: passo 6, imagem 3 %32
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: passo 7, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement, Screen: passo 7, imagem 2 %32 Garmin Dash Cam 20 Screen Replacement, Screen: passo 7, imagem 3 %32
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: passo 8, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 8, imagem 2 %32
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: passo 9, imagem 1 %32 Garmin Dash Cam 20 Screen Replacement: passo 9, imagem 2 %32 Garmin Dash Cam 20 Screen Replacement: passo 9, imagem 3 %32
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: passo 10, imagem 1 %32
    • The screen is now detached.
Conclusão
Uma outra pessoa concluiu este guia.
Jesse Hillman
Membro desde: 10/04/16
757 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-1, Cagle Fall 2016 Membro de USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 607
